Perform this procedure to configure network policies on specific ports.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure a network policy:
    lldp med-network-policies {guest-voice | guest-voice-signaling | softphone-voice | streaming-video | video-conferencing | video-signaling | voice | voice-signaling} [dscp <0-63>] [priority <0-7>] [tagging {tagged|untagged}] [vlan-id <0-4059>]
Configuring guest voice network policy on port 1/2:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabitEthernet 1/2
Switch:1(config-if)#lldp med-network-policies guest-voice dscp 1 priority 5 tagging tagged vlan-id 5
The following table defines parameters for the lldp med-network-policies command.
Variable
Value
Specifies the type of network policy.
dscp <0-63>
Specifies the Layer 3 DiffServ Code Point (DSCP) value, as defined in IETF RFC 2474 and RFC 2475. The default is 0.
priority <0-7>
Specifies the priority level, as defined in IEEE 802.1D. The default is 0.
tagging {tagged | untagged}
Specifies the type of VLAN tagging to apply on the selected ports. The default is untagged.
vlan-id <0-4059>
Specifies the VLAN ID for the port, as defined in IEEE 802.1Q. If you configure priority tagged frames, the system recognizes only the 802.1D priority level and uses a value of 0 for the VLAN ID of the ingress port.
The default is 0.
